Re: test tank
I can run my 20 hp motor in a trash can in gear at idle without blowing out the water--I'd say give it a try. If you're just adjusting idle mix and speed, which must be done in gear, you should be able to do that. You may need to fine tune it on the water. Keep a hose running into it to keep it topped up. Or use a 55 gallon drum if the trash can doesn't work. And don't rev it!
