Test a bilge pump
scanman73
Hello...I have a Trophy 2002 and am having bilge pump problems.
I took out the pump (Johnson 1000 GPH - P/N: 28512), and have attached the two wires directly to a 12V battery - Brown to +, Black to -.
The pump doesn't budge....
Should the pump kick in when directly connected like this? If so can I presume it is time to replace.
If not how should it be wired to get it run?
Thanks!
cribber
Re: Test a bilge pump
If you do not have an internal float switch built into it, then your pump motor likely needs to be replaced. Place it in a bucket of water with enough water to fully submerge the pump and reconnect it to the battery. If nothing happens hit the Iboat store for a new one.
Ayuh,... You've got it,... Welcome Aboard,...
