Temperture gage not working
Gerhard Peters
Can someone tell me if my temperature gauge is not working if it stays up all the way? Or could it be my temperature sensors? It stays like this with the ignition on or off. Even with the battery disconnected, it stays like this
wellcraft-classic210
Master Chief Petty Officer
Hi -- its sounds like your gauge is stuck or damaged ( assuming no voltage present as you described )
Other than verifying no power is present with a multi meter etc it would seem you need a new one.
I am assuming your config is the same as the older boats I am most familiar with // If you can list the year and engine type the experts may have more to add.
achris
More fish than mountain goat
Check both power and ground. If they are both good, replace the gauge. Chris....
Ayuh,...... 12v at the (+) terminal,.....
