Temperature
wjryan9
I have a 150 hp mercury saltwater. What should the running temp be at 4000 rpms?
oldman570
Re: Temperature
I belive the water temp should be around 145 and the head temp near the same. If it runs higher you should check the popit valves and thermostat. Salt water dose bad things to motors if not flushed out proply after use.
Oldman570
