Thank you for your concise answer. I will look for a 1/8" hole somewhere on the block. I don't think my engine "pees".I have put one on my 1995 Sport Jet 90 which is basically the same block. I used a 1/8" temp sender that was the correct resistance for the gauge in my boat. I checked it by hooking up the sender and ground wires to the sender and putting it in a coke can with boiling water (using a propane torch) and seeing that it measured ~212 degrees. I bought the sender on Amazon.
I installed it in the plug at the top of the block. I had a "pee" tube at the time and put the sensor in a TEE. Since I have just screwed it into the hole and forgot about the Pee tube.
I kept the high temp thermo switch on the head and the buzzer it operates.
Thank you for helping me find the right plug. My block is probably the same as yours. Would you happen to have a pic of your completed installation?You will find the plug filling the tap just in front of the head on top of the block. IF as I think it is basically the same as the three cylinder 90 hp engine.
