temperature flashes 32deg always on my fishfinder
Roy Akers
my father-in-law installed a fishfinder but it only flashes 32 deg? tried different transducer - same thing :( i think its a operator error, but ....
any help you fishfinder gurus?
thanks,
Roy
JB
Re: temperature flashes 32deg always on my fishfinder
I have moved this to the correct forum and deleted your other thread.
11. Please do not post multiple threads in multiple forums about a single problem. This is confusing to those trying to help you. Multiple threads in the same forum about the same issue are also confusing. If you want help fast, one thread in the most closely related forum is the best way to get it.
flashing 32 proberly means its not seeing a temp sensor and 32 is proberly the low range setting of the fishfinder. time to read the manual
Roy Akers
Lowrance users: If the screen keeps showing me the 32deg and I have changed the transducer. --- no joy. I even changed the fishfinder and it works with the transducer but not with the original unit. Have I changed everything so far? I don't want to change the unit if I have to (Lcx-19). :(
Signed me.....frustrated!
