Temp Spec's,Overheat Sensor,1989 Force 85
mrtool2u
I am trying to figure out my overheat sensor on my 85 hp force,,,when in a pan of water it activates at approx 165 degrees,,,and when I shut the heat off,it loses continuity at approx 145 degrees.Is this about the right specs,,,1989 85 hp motor.
The Marine Doctor
Re: Temp Spec's,Overheat Sensor,1989 Force 85
At 165 deg...there will be no damage done to the engine..We expect the engine to run around the 140 mark..so your sending unit should be fine.<br /><br />TMD
mrtool2u
Thanks Marine Doc,I thought that this sounded decent,but wanted to make sure.
