Temp sender test 95 3.0LX
fat fanny
Everything is cool as tha tap water going into it but the gauge is pegged ? I had just slightly colapsed the little elbow that connects to the sender so to have a tight connection. Now my gauge os pegged and just to verify it wasn;t overheating I just went out and turned the key and the needle pegged out and it's been @least 4 hrs since it last ran. Any help would be appricieated
Silvertip
Honorary Supreme Mariner
Re: Temp sender test 95 3.0LX
All I've been able to make out is that you have a temp sender and you collapsed something. So lets start from scratch. We know this:
You have a 3.0L I/O
Apparently the temp gauge doesn't work so you mucked with the sender and bent something.
The Temp sender screws into the water jacket, intake manifold or the thermostat housing on the engine so the part that you collapsed is what??
If the gauge pegs when you turn the key on (assuming the engine is stone cold) that says the "S" terminal on the gauge is shorted to ground either at the gauge, at the sender, or somewhere in the wire between the two.
You can measure the resistance of the sender with an ohm meter.
Are we on the right track?
fat fanny
Yes we are and I do not know what happened to the 1st 2 sentences of my post sorry. The only thing I colapsed was the electrical connector elbow on the wire so it would not fall off the threaded stud on the sender after that it pegged the needle.
Silvertip
Buy a new sender. You screwed up the one you had.
NYBo
Those senders are pretty sturdy. More likely the wiring is shorted to ground. Just for ha-has, pull the electrical connector off the stud part way and see what happens. It may be grounding to the sender's housing.
