meangene21
Thread starter- Joined
- Jun 7, 2005
- 26
Hello again !<br /><br /> I had to run my motor with the ear muffs on. While i was testing the motor i noticed no water was getting pumped through the impeller. So now i think i know which manuel to buy and replace that. The motor ran fine other then the extreme heat build up when running it on the bad impeller. There is a buzzer that goes off which warns you of temp overheating. Would that buzzer in anyway effect the engines running ability? The reason for the question is because my motor will not start now... <br /><br />Thanks in advance for the help <br /><br />Yup ima NOOB !
