tell tale volume
Phatslax
Hi-
Was giving my '83 35hp evinrude a go in the dustboin last night and noticed that as the engine became warm the volume from the tell-tale decreased - is this a function of a thermostat opening and lowering the pressure at the pee-hole or does it indicate a worn impellor, I plan to change it ASAP but wondered if there was anything else at work...
Thanks
David
1730V
Re: tell tale volume
You may have some debris floating around in there. The stat opening allows more water into the block.
tashasdaddy
yes, weak water pump. service should be done.
iwombat
the tell tale is before the t-stats. Weak tell tale stream = time to replace the water pump.
rickdb1boat
True. But if you are looking at servicing the system, as good practice, I would also be looking at the stat for any problems..
