Tell tail and upper exhaust
Disschord
Hi I just bought a used Suzuki dt65 when I tested the engine before buying the tell tail was pissing like a race horse.
I got it home started her up in a tub I have loads of water coming from the upper exhaust but just drips from the tell tail.
I tried the wire up the pee hole trick I could only get it about 5 inches is that normal? Unfortunately It made no difference. I ran the engine at idle for about 10 minutes I didn't get hot
Any advice please
deejaycee_2000
Re: Tell tail and upper exhaust
Did you test the motor on the water when it pissed like a race horse?
Disschord
I was only able to test it on muffs that is when it was pissing like a horse but now I have it home I ran it in a bin but I'm only getting water out the exhaust
deejaycee_2000
I would go test it properly just to make sure before you start ordering new parts ... muffs and bins don't give accurate readings .... if it doesn't pee strongly on the water don't ride it ...
metor99
I don't know this motor but it sounds like you have a piece of dirt or something blocking the tell tail. Try running a small wire up it or pull the hose off the usually plastic tell tail end. The end is usually smaller than the hose and things will get stuck in it.
Disschord
Thanks for your help guys I was going to pull the tell tail pipe off today and try the wire trick as metor suggested today but unfortunately I blew a 25Amp fuse starting it.
So I have to sort that out first before I can move on
I'm starting to worry that I bought some junk
