ted williams 7.5 question "pics"
wizzy214
i belive this motor to be a ted williams 7.5?
what year is this? im thinking its a 72'
took it apart because of blown head gasket. motor is in good condition.
metal tab behind carb reads T-7103804 and 6675420
another says sears roebuck 217-58820
also what type of metal is it made out of? steel? magneese?
heres some pics
thanks
wizzy214
Re: ted williams 7.5 question "pics"
ok no replys, took it completly apart, im going to part this out. watch ebay.
everything is in great condish for being so old.
have fun
Capt Ron
Aluminum and pot metal with a steel cylinder liner and crankshaft.
A magnet will help tell.
CaptRon
JB
That head looks like it came from a Tecumseh AH61 chainsaw engine. You should be able to find a head gasket by taking it to a lawnmower/chainsaw shop.
Magnesium/aluminum/nickel alloy castings, steel cylinder liner and moving parts except piston and flywheel.
steelespike
Most likely built by Eska using a Tecumseh power head.and a water cooled leg with a pump.Eska is out of business.
wizzy214
still trying to figure out the year?
if it is a Tecumseh AH61 chainsaw engine, can it be used as something other than a outboard motor?
possibly some thing with two wheels?
wizzy214
is there a forsale thread, or another site to part out old outboards instead of fleabay????
and what are the parts worth? or do you just go by what ebay and craigslist list....
thanks
wizzy214
its also the model that has a fuel tank on top of the motor and the option to run another additional tank.
thanks.............
CATransplant
Ebay is your best bet. You could use Craig's List in your area, but you won't reach that many people looking for parts for that outboard.
As far as what they're worth, you could look at ebay's completed auctions. You won't get rich, but some of the parts will probably sell.
For some things, like outboard parts, ebay is the only choice that will get them sold and for what the market will bear. Every other way you can sell will take a long time and you'll make less.
wizzy214
parting out this 1972 TW on ebay.
just thought i'd let ya'll know
