todd ashley peters
- Nov 7, 2010
- 56
I traded a guy for a seaco 9.9 that had the trigger magnet let go at WOT. well the cdi's were smashed beyond. so i took them out compleatley and kept the charge coils in place. I welded tabs on the stator to accept the new omc triggers. I then took the triggers and modified them to fit in place on the stator. this was done with a benchtop bandsaw and a craftsman disc sander. so if you are handy it souldnt be too difficult. got the omc cdi module from a 82 johnson 20 hp as too the coils..found a wiring diagram at the cdi web site. made some brackets and mounted the omc cdi and coils to the out of the block. i"ll change out the old kill switch for a teathered one when i put it in the outboard body.
Any takers wheather it works or not. untested . barrel is froze solid for another month or so. have to wait till then i guess.
i"ll try anything once or twice.
