81 Checkmate
- Jul 20, 2010
- 1,360
Just thought i would pass on my experience with referbishing my Teak swim deck and Teak wood trim.Been reading on iboats/ google for best results.
Here is what i came up with:
1. Remove all wood from boat if you can.
2. Pressure wash wood.
3. Tri sodium phosphate with hot water and pot scrubber. ( This i did not do )
4. Sand wood with sandpaper. ( I used 120 Grit Alum Oxide paper )
5. Blew off wood with compressed air.
6. Wiped down with cheese cloth.
7. I applied each coat then let set a few min, then wiped down with rag.
8. Before the last coat i sanded with 00 steel wool, then air, then cheese cloth
9. Applied last coat.
10. Total of 8 coats on the swim deck and 4 for the rest of the trim.
Now if i had to do it again! I would use the tri - sodium and use 80 grit sandpaper.
Also everyone said they had good luck with Amazon Gold Teak oil. I just went with the big box brand that was on the shelf.
Total Materials.
2 Quarts of Teak oil
2 packs of cheese cloths
1 pack of 00 steel wool
1 roll of 120 grit oxide sandpaper ( Borrowed from work )
5 Sponge type paint brushes 1 1/2" wide
