Teak Restoration
bds85466
I'm sure there's a good tried and true method out there regarding this topic on this forum. Can someone point me to it? Thanks!
Re: Teak Restoration
In the process of re doing all my teak wood. best result i have found which looks absolutely great. "and my wood was bad real bad" I first pressure washed the wood to remove dirt and moss etc. I then let it dry for roughly for 2 days in the sun, sanded with 120 grit and then again with 280 grit, wiped down with acetone and final sand with 400 grit and a wipe down with acetone again. I made sure wood was dry by letting it sit in the sun for 2 more days. I then applied 2 coats of sikkens cetol marine light after it dried completely i then used sikkens gloss over the top. this produced an absolutely stunning result that should last for years. all my teak came back to life. in large cracks "very large almost 1/4 inch wide and all the way through" i used plain gorrilla glue to fill it in and then sanded over the top to make it flush.
bds85466
Interesting. Where can I get some sikkens cetol marine light? Also, anyone know where I can 2 days worth of sun?:)
External Combustion
The classic answer is bleach, sand and varnish.
It worked for over a hundred years and it will work for today, yet......I think there are modern answers to the problem!
Keep posing the question if you are adverse to labor!
Silver Heels
Hello,
I have refinished the teak on many boats in the past. I would also strongly recomment Cetol. Very durable, easy to apply and requires minimal upkeep. It is not quite as beautiful as brightwork that has been painstakingly maintained vith varnish, but is much less time consuming. Some advocate teak oil, but it has to be reapplied much more often and it does not stay looking good very long. I worked in a marina and would definately not advocate using a pressure washer to clean teak, however. One boater comes to mind that owned a large Chris Craft. He pressure washed all the teak only to find that it cleaned it very well and brought back the orangish color of the wood, but it also opened up the grain and gave the teak a very rough, porous look. In effect, he blasted out all the softer fibers of the wood between the grain lines and ruined the brightwork. I have used teak cleaner, applied with a soft brush with good results. Do that, let it dry, then sand with 120 grit sand paper. Follow it up with three coats of Cetol and your good for quite awhile, depending on where you store your boat. I have also used Cetol light and Cetol with a top coat of Cetol Gloss which very closely resembles a quality varnish job. I have bought both the teak cleaner and the Cetol at West Marine, though it is available elsewhere. A quart of Cetol runs about $35 which is plenty to do your average boat several times over. Good Luck
salty87
2 part cleaner/brightener is pretty simple to use. iboats sells it, you can usually find it locally too.
the chemicals do the work...get the wood wet and scrub with a brush, rinse off. then cover with teak oil or cetol or whatever. teak is an oily wood which is why its used on boats, urethane's and sealants won't necessarily adhere very well. i just stick to teak oil a few times a year but cetol is commonly used, i just never tried it.
bds85466
What to use as a cleaner before you sand? Bleach?
marine4003
yes,bleach...or go to your local boating store and buy Teak Restorer, its 2 part..one cleans..one bleaches...
25thmustang
Anyone got any pictures of before and after. I am just finishing the redoing of my Mahagony on the cabin doors and interior but plan to tackle the teak next. The steps sound great, but finished products always help with the mental image. :D
Gary H NC
Not sure how well you can see in the picture but my teak cabin doors and side rails were in terrible shape.They had turned gray and was very rough.This is after sanding it all down and wiping it with Starbrite Golden teak oil.The other brands were too thin and had less color. i added about 3 more coats after this picture and it looked great.I wipe over it every couple months to keep it looking good.Takes about 5 minutes..
JB
I have used Star Brite with success. Three parts: cleaner, brightener and oil. More oil every few months if it is kept in the sun. I think that Cetol is probably better than Star Brite's golden teak oil, but I never needed it.
If it is too rough sand it before the cleaner.
marine4003
Gary...NICE BOAT ! I love the old Scorpions,she's Bristol !!
alaska_av8r
Does Cetol make a product that will leave a "matte" or non glossy finish.....I am looking for something that will leave a "satin" finish.
Moonglade
Hi! I usually find the information I need and drift away but the question on teak restoration is one I have struggled with several times. Star Brite is a good product and bleach and sanding,followed by teak oil is a time honored way but somewhat labor intensive depending on the amount of teak on your boat. A local boat shop manager I became friendly with recommended automobile tranny fluid. I was a little leary but applied it to a 1989 Procraft bass boat that I replaced all whatever wood was on it with red oak. ( I'm, a amature woodworker ) I applied it in the spring and later in mid season and twice a year thereafter and the guy that bought the boat two years later thought she was the prettist thing he had ever seen. Warning!!! The oil does produce a slightly red warm sheen (darker) and not the true golden look of teak oil. I have also pressure washed my teak, be careful it does strip the wood if done too hard.:eek:
Tail_Gunner
Wood is wood and how you bring out the beauty of it makes no difference. I like your method you have captured the beauty of teak for year's.....Do you custom refinish's..if not very good imagination..;)
Tail_Gunner
She's a very elegant lady, Job very nicley done...:cool:
