TD20 Parts Question
Woodie Wrench
I am working on a very old [1946-9] TD20 for a friend. I think of myself as a decent 2-stroke amateur mechanic, but I am far from an expert, and this is my first forum post, so please excuse me if I get the terminology wrong. I have gotten hold of the Johnson Motors catalog, so all terms and parts numbers are coming from that source. The motor is missing a sleeve that is mounted on the drive shaft casing. It appear to me to be listed in the catalog as part number 41-52, and is called a "Lining - Pilot Band." Searching around on the web, e-Bay, parts sources has gotten me no listing for this part number. It appears to me to be a sleeve with a single slit and two holes in it. The sleeve looks to me like it should be made of material about 1/8" thick. The two holes are about 3/32" each and fit two metal pins on springs which protrude from the drive shaft casing. Once in place, this sleeve rides in what is called a "thrust socket," but which I would describe as a "half yoke" that is mounted at the bottom of the stern bracket. I know this is an old motor, but I read great things about what workhorses these are, and I know that letting the raw metal surfaces bang on each other is not the answer. If anybody has a source for this part or can tell me what it is made of or what material would make a suitable substitute so that I can make one, I would be most grateful. Thank you.
flyingscott
Find a black PVC pipe in that diameter or close to it. With PVC you can glue 2 pieces together to form the ring. Or you can get a sheet of 1/8" HDPE plastic and form one out there will be a little harder to make but would work well.
F_R
Honorary Supreme Mariner
I agree, the part is no longer available. Make one as flyingscott suggested. You may need a friend with a lathe, if correct size material is not available. The original was some sort of fiber stuff that resembled wood, but wasn't. PVC pipe would work just fine.
