TCW3 Oil
jeeprider10
Hello I recently bought a 93 javelin it has a 115 Johnson Evinrude 2 stroke on it. My question is the previous owner used the TCW3 oil in the oil tank. I recently bought the XD-50 is it ok to mix the oil or should I empty the oil tank and then add the xd-50? Thanks for the help
GA_Boater
Welcome to iboats.
I wouldn't dump the TCW3 in the tank now.
XD 50 meets or exceeds TCW3 specs and will mix OK. If you are concerned, run the TCW3 in the tank until it needs refilled and then use the XD 50 to refill.
jeeprider10
Thanks GA_Boater for the welcome and reply. I thought it would be ok but wanted to make sure. First time boat owner and all.
