Tankless Hot Water Heaters
roscoe
Re: Tankless Hot Water Heaters
My brother-in-law and my cousin are both plumbing contractors.
THey will install them, but spend plenty of time trying to talk people out of them.
THey explain about all the maint, instal, repair issues.
Often times they can't repair them for lack of parts and tech support.
BIL says that in larger homes, he installs 3 of them in different locations, and the extra install costs and logistics can be a pain and costly.
They also warn about temperature rise issues.
Claims by manufacturers are inflated.
Says he has installed a few dozen, and on at least 10 units, he cannot get the claimed temp rise.
This is a big issue here in WI, as our ground water is 40-45*.
Trying to get 70-85* temp rise can be problematic.
One option is to install a second, smaller, electric tankless heater, to "pre-heat" the water 20-30 degrees so the main heater can reach the desired temp.
I too will be keeping the old style tanked heater for many of the reasons stated, and any heat lost from the tank and pipes is used to warm my house, so it is not necessarily all wasted energy.
NYBo
A little off the topic: The masonry chimney in your thrid photo looks awfully ugly.
BlkY2k
I've been doing some research on these lately. This will probably be the last season for our Nat-gas boiler and I have been looking at a Rinai combo unit. It is a boiler and water heater in one. It seems to be a very efficient systems that uses a sensor mounted outside that communicates with the boiler and adjudts flow rates to compensate for temps. They run about $2800. which doesn't seem to bad for a all in one. Plus all the space I'll gain and not to mention the efficientcy we will gain from the boiler itself. Our old one is 25 years now.
