Tank Question on specifics
baseboy47
I am purchasing a 1956 Evinrude 7.5 HP Motor, and I am new to the boating scene. I was wondering what I exactly need to make the motor operational such as fuel tank and hoses? Any info would be good. The motor is coming as is and does not have the hoses that go to the tank as well as a tank. Also a round about price if anyone knows for the tank and hoses. Thanks
oldboat1
Re: Tank Question on specifics
$50 to $100 for a used tank w/dual line hose and connector.
baseboy47
OK thanks I was hoping that was the round about number.
HighTrim
You need a dual line pressure tank, NOT a single line tank.
The '56 does not have a fuel pump, so uses the pressure tank to supply fuel to the carb. A fuel pump can be installed if you so choose, and run a newer single line tank.
Post a wanted ad at aomci.org in the webvertize for a known good tank. Likely get one for 50 bucks or so.
