Tanaka 1.2 hp tob-120 lean rich setting???
kenpearce
I've recently acquired a Tanaka 1.2 hp engine and am having trouble getting it to run at full power. It starts ok, runs a little rough I'm assuming because the mix is too rich? I'm not finding any documentation or discussion that this engine has a lean/rich mixture adjustment. I recently replaced a missing float needle which would explain why fuel was running everywhere, but it still runs too rich. When I shut off the fuel stopcock it runs beautifully when it's finally running out of gas, but only momentarily of course. <br /><br />Is there any adjustment on the carb jet? <br /><br />I precisely mixed my fuel 50:1 and used 2-cycle oil made for chainsaws and outboards...<br /><br />Thanks in advance, <br /><br />Ken<br />Bellingham, WA
steelespike
Re: Tanaka 1.2 hp tob-120 lean rich setting???
There could be a low speed adjust but not likely a high speed.Be sure the high speed jet is in place.<br />My guess is the float is set wrong,bent,gas soaked.Float valve may be hanging up.Flip the carb over and blow into the gas line.Usually the float is roughly level when closed.
wv fisherman
Ken, Ive had the same problem, one word will sum it up.... points, make sure they are "perfect" you can get a manual from tanaka.com they will email it to you... wv fisherman
