Re: Talkin Torque
I am still confused by what they show there as I see no indication that Merc or Volvo buy those "complete" marine engines. It does look like PCM and Crusader are using the 6.0 with the latest ignition and aluminum heads. We'll see. What is also confusing is that I don't believe GM has done any development with a Catalyst, so if you are a packager of complete marine engines you MUST have your own engine development cells and group. I am sure they use places like Southwest Research, but I don't see how GM has added enough value to result in widespread sales of the high performance stuff. Seems like there is no way to simply take those engines, add drives and transmissions and sell them. So IF you have to do development yourself in any volume, why pay GM for completes that are not ready for the market? It appears that's what the big guys have concluded.
I have been doing quite a bit of research lately on the 4.3 which is closely tied to the 5.7.Gm has done volumes of updates on head design and applied the results to both the 5.7 and 4.3 And being in the auto ind most if not all of the hp advancer's have come from air induction system's and ecm programming.
Ford long ago abandoned push rod motor's in favor of OHC motors. The duratech line which is the 2.0-3.0 soon to called ECO boost motors..The Triton motor's in the 4.6-5.4 and 6.0. Using synthecis to build intakes and finally going to 3valve designs and today they have a little 281 cu that does 320 hp that is as solid as rock...(Mustang) OHC in a boat..not
Gm on the other hand seems to keep with there push rod motor's, and doing a lot of development with head and cam tech. Here is a older link showing just how much they have done.
http://www.thirdgen.org/techboard/tbi/336750-tbi-tpi-heads-headflow.html
Middle of the page
EDIT:
This post (WOW!!! GMPP Aluminum Vette Heads) describes just how good the factory L98 head castings are now, after 10+ years of tweaking to the casting (back cut valves, smooth radii etc). So the newest 113 casting have nearly no room for porting... although the owner did use sanding rolls before he got them flowed
You have to read it all but Gm has been going a different path increasing effiecny and selling on hell of a lot of low cost boat motor's along the way. Note the tinkers do not any longer port the newest heads.
I seriously doubt other than mapping ecm's Volvo or Merc do little else than buy prepacked engine's speced out to there liking. I do expect some or would think changes.... in just how they setup there ecm's, from what i have read so far they run the motors in a overly rich condition for safety reason but with the new epa regs coming down that should change.
Take it a bit futher, you work in deisel tech. I am sure you know of Ford's law suits with Navistar on the 6.0 and failure rate's...Navistar sold Ford the tech..prepackaged,
