taking on water
Onexl85
Taking on water from the outdrive, this is a photo looking from the engine toward the transom
It's a good stream coming in, what are the most common causes?
U Joint bellows?
Shift bellows?
Onexl85
No Title
Onexl85
Looks like it stops leaking with drive all the way down
Alumarine
As a rule if the leak stops or slows down when the drive is down then its most likely a bellows probably the shift bellows.
When you take the boat out to inspect it tilt the motor all the way up and you can inspect the bellows.
Onexl85
Is the shift bellow a pain in the ass to change? I did bellows on my penta sx before I sold it
Is the shift bellow a pain in the *** to change? I did bellows on my penta sx before I sold it
Ayuh,..... Generally speakin', if yer gonna change a bellows, ya change ALL the bellows, 'n the lower shift cable, ALL at the same time,.....
If ya use the trim stop switch, 'n trim indicator, ya oughta change 'em also, at the same time,...
Onexl85
Would you guys stick with quicksilver parts for the bellows? If so who has the best deal?
