Re: Taking on water???
Wow that really makes me wonder. I know my boat has flotation foam, and I also know my boat has a tough time getting on plane with more than one person in it.
I will do a search on how to check for water logged flotation foam, do you have any suggestions? I guess I haven't worried about it because the wood floor is solid everywhere.
I am in the middle of replacing and fixing my boat that was foam filled. In my situation the previous owner had made several "upgrades" (That is sarcasm) and left a few unfilled holes here and there. We did not have any holes that were obvious but many small holes that did some serious damage. Once that foam gets waterlogged it pretty much game over.
It sneaks up on you. Its hard to get up on a plane at first and then after a few more trips when you put more then 1 person in the boat it gets considerably worse. My boat should carry 4 people and gear just fine but after 2 people it just lost its go power.
Ultimately what happened in my situation was our 1991 90hp Johnson just got tired of pushing that extra weight and we blew the rings up. Maybe it was destined to happen either way but all of that extra weight was just way to much.
What I have learned is that waterlogged foam is fixable for sure but it is a project. In my case I am having fun fixing it but it is a lot of work. I had the deck off of my boat for a week, gave the transom a brief looking over and everything seemed to be fine. Most everyone said they were surprised the transom made it without rotting. Well to my surprise I was totally wrong did find rot in the transom. Make sure you give your transom a very good looking over!
Oh and another thing that I learned that might help a little bit. Our boat has 4 drain plugs in it. 1 for the splash well (thats supposed to be there) and 3 others. Well the previous owner drilled them other 3 in. Even though they looked right they were not supposed to be there on our paticular foam filled boat. The plug in the dead center stern had been leaking water around it. The drain hole for the anchor locker was also leaking a small amount of water. Enough to water log and rot the foam around it. In our case the black foam is totally rotten and water logged while the darker foam was just water logged.
http://forums.iboats.com/showthread.php?t=404623
I have heard of people running warm air through their boats for a couple months to dry the foam. Goodluck to you and check for them small holes that you might of over looked!
