Gomer50
Thread starter- Joined
- Sep 5, 2009
- 507
My Motor seems to run pretty good but I am a little concerned with the timing,I have read the link and synch procedure and have read the manual several times and still not sure. Number 1 the only thing on my flywheel as far as markings are 3 dots and if I am doing this right, I used a dial indicator to find TDC on Nr.1 piston, the 3 dots line up with the arrow on the distributor gear thats good everything in a straight line. Now on my Motor I dont have a Timing pointer,although on the top of my engine cowl is a timing gauge,so I thought I would just put a mark on the flywheel that matched the TDC marking on the cowl when the Nr.1 piston is @ TDC. According to the link and synch as I advance my throttle the timing advances as well. The throttle pickup should start to open the carbs around 3 to 4 degree's BTC well in my case this doesnt happen.Mine seems to be Idleing at 3 to 4 degrees BTC and start to open carbs at 8 to 9 degrees BTC. So when I set max advance to 23 degrres BTC I dont think thats correct. Any input on what I am doing wrong?? Thanks Guy's
