taking on stream of water
jkleinh
i have 1987 5.7 omc cobra where the exhaust manifolds meet together at the back of the transom there is a v like impression in the manifolds i have a stream of water comming in from somewhere just above that v but connot see where. is there a bolt somewhere up there or whatt??? boat does not have to be running for water to come in
chiefalen
Re: taking on stream of water
You maybe have a torn boot ? On the out drive. Coming in thru to the inside via the gimbal bearing or shift cable boot ?
I'm afraid ya got to yank the drive. And check it out ?
Got a manual ?
a70eliminator
If it's not coming from around the exhaust connection itself, then the only place I can think of right off that would cause a stream of water is the trim sender hole in the transom, that portion of your exhaust would be flooded with water at all times you know, leaking u-joint bellows or not.
chiefalen
My friend had water p--ing on the motor we found the water was coming up the cable.
When was the last time this 22 year old boat had the boots changed ? If ever.
When you get around to it and yank the drive i hope it didn't drop, and causing the water as you suspect coming in thru a bolt hole.
Than you got problems with a bad transom.
And turning the nut tighter is not gonna fix that.
Pray it's the boots.
a70eliminator
Try running your engine on muffs, if it doesn't leak, then you need to pull the drive and have a look. Oh wait a minute you say it leaks even without engine running...your looking at pulling the drive at the least! But then again there is that pesky flapper valve, it's secured with a drift pin through the exhaust tube housing, but thats a long shot.
Don S
I'm not exactly sure of what you are referring to, could you possibly post a picture of where your leak is.
jkleinh
im knew so bare with me i could certainly try posting picture, the transom is in excellent shape the boat has been dry stored since new the bellows were replaced two years ago max from the outside they look great i was thinking on shooting some silicone in the hole where the shifter cable goes and see if that helps
Don S
Come on man .................. Get real
Find the problem and fix it correctly.
jkleinh
i know im not the half a-- type but my thought was that if it does slow down or subside then i know that its the o ring that ive been told is up there thats why i said silicone and not 5200 the silicones easily removed i dont think its the boot im leaning toward y pipe or o ring at shifter cable its a verry nice boat its allways been dry stored i just recently obtained a trailer for it the two previous owners the first being the origional are neighbors and one is someone i do work for all questions concerning boat can be easily obtained
chiefalen
Read what it says on the bottom of Dons posts. And if you use this boat in saltwater your gonna have even bigger problems and in real short order.
