Mercruiser 4.3 MPI
Serial # 2A046127
Engine won't exceed 3400 RPM and doesn't have enough power to get on plane without ballast on the bow.
Fuel Pressure holds and is 43 at 1800
Cap and rotor replaced ( suggested by many on other forums)
I replaced the output O2 sensors as the didn't seem to read on the diacom graph.
Lon term fuel trim is 4 or 5 left bank idel and 16 to 17 right bank idle but both seem to decrease with higher idle.
The throttle lever always says 0 but the throttle plate changes with the increase of throttle.
I will try and downlod the Diacom Recording if I can. Not sure if it attached it says failed couldn't be written to server?
Any help would appreciated
Rick
Serial # 2A046127
Rick
