need to know how to hook up a tach to determine right prop on my 1995 150 oceanrunne
H hollywoodwayne Seaman Joined Aug 27, 2008 Messages 58 Aug 27, 2008 #1 need to know how to hook up a tach to determine right prop on my 1995 150 oceanrunne
D DJ Guest Aug 27, 2008 #2 Re: tachometer What kind of control do you have? If it's a side mount, there is a plug right under the key and throttle tension knob. If you have a top mount (binnacle) the grey wire is the one you want for the tach. signal.
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Aug 28, 2008 #3 Re: tachometer a little visual for you
H hollywoodwayne Seaman Joined Aug 27, 2008 Messages 58 Aug 28, 2008 #4 Re: tachometer its a side mount,found the plug,its a 3 pin with a flat side.I guess all i have to do is buy the gauge and harness?Thank you Wayne Lowe
