Tach just hangs around 700 on motor,Merc 150 V6
C chumbucket Petty Officer 1st Class Thread starter Joined Oct 12, 2001 Messages 320 Sep 9, 2002 #1 Tach just hangs around 700 on motor,Merc 150 V6
S superman Petty Officer 2nd Class Joined Aug 23, 2002 Messages 133 Sep 9, 2002 #2 Re: Tachometer If your getting 12 volts to it then sounds like you have lost your pulse from the stator or bad tach. Check the connection from the tach to the motor.
M mellowyellow Vice Admiral Joined Jun 8, 2002 Messages 5,327 Sep 9, 2002 #3 Re: Tachometer not sure what year your motor is, but my '70<br />115hp, the tach runs off the rectifier. I would<br />start there. cost $35 new.<br />good luck,<br />M.Y.
