Tachometer wiring?
mike8282
I'm trying to wire a tachometer to my 86 Johnson 90 hp. If anyone could tell what wires from the outboard do I attach the wires from the tachometer?
Silvertip
Honorary Supreme Mariner
Re: Tachometer wiring?
There are four wires on a tach -- only one of them comes from the engine. The wires are as follows:
L = internal light connection -- connects to the light terminal on any other gauge or to the NAV side of the navigation light switch.
Ground = ground -- connects to the ground terminal on any other gauge or the ground lead in the engine harness.
+12 Volts = This connection is labeled "I" on most tachs and is connected to the "I" (+12 volt) terminal on any other gauge or the "A" (accessory) terminal on the ignition switch.
S = Send terminal -- Connects to the TACH signal from the engine harness. Depending on the year of the engine, there will be a three terminal plug below the ignitiion key on the control box. +12 volts, ground and S (send) are available there via an optional tach harness (available from the dealer or possibly here on IBoats).
ezmobee
The gray wire in your control box is the pulse feed for the tach.
