tachometer question
minocqa
hi<br />i have 1976 70hp johnson 3 cylinder :) <br />i want to install a tach on my boat for it. but all the tach's i have seen, seem to be for 4-6-8 cyl motors <br />do i have to have a special one just for 3 cyl or will one of them work? :confused: <br />thanks<br />Don
Hooty
Re: tachometer question
The numbers you're seeing probably aren't number of cylinders but number of pulses from your stator. A two cycle Teleflex tach set on "6" will work on your engine.<br /><br />c/6<br /><br />Hooty
minocqa
hi hooty<br />thanks for the reply<br />i was looking at a tach made by OMc that was listed on ebay the back showed a c=cly and p=pulses thats why iwas confused <br />but if i get one and set the pulses for 6 it will work on my 3cyl... 2 clcle.. ok then huh?<br />thanks again<br />Don
Hooty
Ooops. Don't know Don, I not sure about the OMC tach. I guess, if the price was right, you could buy it an' try it.<br /><br />c/6<br /><br />Hooty
