tachometer question
achee7114
I have this tachometer Westberg twintach. Called the company they said they have no info they stopped making them in the mid 60's. Should it have a sending unit ,only two screws ,no ground?Are they both hooked up to magnetos I have two golden javelins only want to use one this summer how do I do that and what is missing here. All info on this unit would be appreciated.To cold to hook up now. IMG_3067.jpgIMG_3068.jpgIMG_3070.jpg
UncleWillie
Re: tachometer question
That is not a tachometer. It is a synchronizer.
It tells you which engine of the pair is running faster than the other.
The 60 on the end of the scale is 60rpm, not 6000rpm.
Its purpose is to get both engines synchronized at the same rpm so the beating hum doesn't drive you crazy.
Originally, it was connected to both engines.
You can use it as a Tach, but only as long as you do not rev your single engine above 60 rpm. :facepalm:
agallant80
Thats pretty cool but I would relegate it to shop decoration duty.
achee7114
thanks for your help, im glad i did not cut a hole in my dash for that thing!
