MokiCruiser
Thread starter- Joined
- Sep 19, 2009
- 47
So I already posted below but I'm not getting any responses so I'll pose this question another way, maybe someone else will see it. I am not too savvy when it comes to electronics but I can usually muddle my way through anything if I get a little advice, so then here's my question another way. According to some posted questions I've read her at I-boats about 1975 Johnson 70 hp motors, I've learned that this 3 cylinder model Johnson needs a 6 pulse tachometer. So my question is, is a pulse a pulse? As you know, anything designed for an outboard can be expensive, but for some reason used snowmobile tachs are relatively cheap. So if the snowmobile tach says that it is 6 pulse (printed right on the back), is there any reason that it would not work with my Johnson. I'll add pictures from one I can buy at Ebay for very cheap (and there's quite a few). Thanks and would really like some help from anyone that might know.
Also if it would work, would the wiring be red = positive 12 V, and black - ground, and yellow the signal (brown on the Johnson)?
