npd4432
- Apr 18, 2006
- 468
I have a 1997 60 hp Johnson that has the system check setup. The boat came without a tachometer and only had the horn and the small gauge with the indicator lights. I installed a system check tachometer and it worked fine for the first couple of weeks. After some time, the gauge began to jump around and give false readings. It works sporadically at best. It also does not reset when the ignition is turned on, even when not running the needle jumps around. Is this just a bad tachometer? Or possibly some faulty wiring somewhere?
