Tachometer not workin on 3.0L Mercruiser. Where to begin?
jpdragon
I have a 3.0L Mercruiser (Maxum 1998 1700SR). Bought last week and the tach is not working.
Where should I begin troubleshooting?
I had already repair the Speedometer gauge. I have a bad trim sender. Can the trim sender be repair or must be replace?
tschmidty
Re: Tachometer not workin on 3.0L Mercruiser. Where to begin?
Also check for ground connection on the back of the tach. You can try cleaning the trim sender but a lot of times it needs to be replaced which is not as easy as you would think.
jpdragon
If I put the volt meter on the tachometer cable. Should I get any voltage reading from those cable? "Purple" / "Purple" / "Black"?
Alpheus
Did you read the manual I provided?
You should have 12 volts from purple to black. Their should be a gray signal wire back there also. If not that most likely is your problem...
imported_TheMan
If it used to work and it no longer does, the tach has probably bad. I've got to replace one myself...
