trebot, I personally have no idea anything about your engine. Especially being so old. BUT, most engines hook up a tach at the stator output before the rectifier/regulator. Because the stator pulses and the tachs read those pulses to determine RPMs. So if you don't have a gray wire coming off the rectifier on the stator input side, choose one of the yellow wires and try it. If your engine doesn't have a stator for charging the battery, then you will have to use one of the spark coils and use a different type tach for that setup...
