Tach Question
maineiac5586
Master Chief Petty Officer
I Have A 76 Merc 500 And The Tach Is Not Working Properly. The Tach Won't Read Above 3000 Rpm, But It Works Ok From 1000 To 3000. I Assume The Motor Is Revving Higher Than This Because When I Give It Full Throttle It Seems To Go Into Its Powerband And Plane The Boat. Boat Is A 16 Foot Duranautic. Speedo Shows Top Speed Of 29 Mph. Sound About Right?? Can I Replace The Tach With A Newer One And If So, Are Wires Compatible On Tach?
jimg984
Re: Tach Question
could be a shorted recetifier, this where the tach sending wire connects, the recetifier changes the ac volts to dc volts
maineiac5586
Re: Tach Question
also noticed battery is only getting 12.3 volts at idle and when motor is idled up in neutral.
jimg984
Re: Tach Question
look for two yellow wires coming from under the flywheel attaching to it, the brown tach wire will attached to same place as one of the yellow wires
maineiac5586
Re: Tach Question
problem solved, replaced rectifier, tach now works and battery charges thanks!!!!
sc00ter78
Re: Tach Question
Was the rectifier difficult to remove?
I think I need to replace mine, will be testing it this comming weekend. I can't find my service manual.
maineiac5586
Re: Tach Question
piece of cake, it was located above switchbox to the left of starter
