i checked the voltage at the back of the tach it read 12.6, when i turn on the key the needle does not go to zero as it should, i got new tach and hooked it up just like the old one, turn on the key and it goes to zero as it should, start the baot and nothing it just stays on zero. so is it a bad connection on the motor where the grey wire hooks up to the motor.Also is there a way to check the old tach with it being out of the boat and not hooked up to anything, could i test it with a ohm meter ?
