Tach problem - 90 yamaha
fisholdschool
Hi there, I have a problem that you may be able to help me with. I have a 1988 90hp yamaha, and lately the tach has been jumping right up to about 7000rpm when I start the engine... and it stays there..no matter what rpm I am actually at... I checked the connections on the back of the tach and they seem alright... could it be something on the engine side of things??? Thanks in advance for any suggestions.
Tony
remi
Re: Tach problem - 90 yamaha
I have a 1989 70hp yamaha with the same problem.When I start it the tach shows 7000rpm all the time eventhough my motor id ideling. Another problem I have now is that it feels like a rev limiter kicks on at full speed and cuts out my engine. My motor must be reading my faulty tack.
I was told its probably the voltage regulator.
Anyone else have this problem?
Eagle180
I had the same problem with my tach on my F115 - 4 Stroke Yahama. Thought it was the voltage regulator/rectifier... had the dealer check it out while the boat was in the shop for other items. Everything checked out OK. Dug a little deeper into the problem and decided to replace the tach with a new one... problem solved! My new tach works perfect, so mine was a bad tachometer.
If you do decide to purchase a new tachometer, be sure to google around for best prices.. most sites I found avg. about $70.00 for one, but I did find same brand and model for about $40.00.
Good luck
remi
Was your engine also cutting out at high speed?
Do you remember where you purchased the tach for $40.
