midsized johnson
Thread starter- Joined
- Jul 28, 2005
- 155
My outboard's tach started acting up a few weeks back. Didn't think much of it, just though the tach was going bad. Fast forward to this past Sunday and the engine has no spark due to low battery. I got it to run hooking it up to my trolling motor battery and everything was working fine. However, later in the trip, the tach started falling off or jumping erratically and then working fine again. It would be working fine then quit if I moved the jack plate up or down. Yesterday, I charged the battery and cleaned all the terminals real good. The battery was reading a bit over twelve volts this morning, then when I started it, it jumped up to 13+ then as high as 14 while it was in high idle but never hitting a number and staying on, sometimes a bit higher, sometimes a bit lower. Once it dropped down to normal idle, it was producing 13.25, but not staying on a consistent number, possibly dropping a hundredth over time. I didn't stay on it, so can't really confirm that, but it was staying right in that range while I had the volt meter on it.
If the rectifier goes bad, does it go all bad, or does it slowly crap out? Maybe both?
Thanks in advance.
Thanks in advance.
