Tach on 90hp tohatsu not working
mugen24
yes i just install aftermarket tach wired like it said , it powers up but no signal
pvanv
Re: Tach on 90hp tohatsu not working
What model motor, and what kind of tach? If this is a 90A, it's intended to use an alternator-signal tach, but an inductive unit should work. If you are trying to use a coil-signal tach, it probably won't work, as the pulse is very short in duration.
The TLDI has a special tach that is used with the onboard diagnostics.
mugen24
Yes i have a 1996 90a not sure what kind of tach but i will see if i can find out tonight. the instruction showed you what wires for tohatsu
TOHATSU GURU
Aftermarket tachs are problematic on Tohatsu's. Those tachs usually have erratic readings.
mugen24
i have a tach that come with motor can i hook it up without trim sender it has white and yellow but no ground.
mugen24
Does the tach have TOHATSU on it?
Yes its a tohatsu gauge i went home and checked to see if motor was charging battery and all motor voltage was 11.8 idle and WOT. does charging circuit work tach.
pvanv
Yes, it's an alternator-triggered tach. You may not be charging.
mugen24
i checked the solid white and solid yellow wire coming from stater to rectifier it had 0 ohms on both have not check rectifier yet
