belairbrian
Thread starter- Joined
- Aug 21, 2009
- 360
Engine is a 1989 Johnson 48 SPL.
Boat has no instumentation. Would Like to add a tach. Did some searching and found this motor would be 10P.
Will use GPS for speed.
Also found a foot note (can't remember where) that said a voltage regulator or 2k resistor might be need for SPL motors to prevent rectifier damage. Anyone got any further insight on that.
Would I be better to just mount a digital (tiny tach) that uses an inductive loop around a spark plug wire?
Any issue with this type tach?
Obviously mounting the tiny tach would be simpler than cutting a hole for a dial tach.
