Tach and trim gauges are doing strange things...or it is normal?
arrivederci
See this photo... I'm no expert, but I know the engine was not revving at 6000 rpm. The tach jumped around and stayed at 6000 even though I was going under 30 MPH. Lake conditions were pretty calm, under 1 metre waves. Is this normal? What should I do?
Please give me some advice, at this speed (seen in picture) is the position of the trim ok?
Thanks for any advice, have had great response so far with my previous question and this forum beats any other boat forum I've tried!
Re: Tach and trim gauges are doing strange things...or it is normal?
bad ground?
arrivederci
Thanks Scott....do you mean we should add a wire from the battery negative to the motor?
seabob4
No, he means check the ground terminations on the back of the gauges, make sure they are tight and that you have good continuity between them and a known "good" ground...like the negative battery terminal...
bruceb58
Honorary Supreme Mariner
There is a switch on the back of the tach that selects how many cylinders your motor is. First note what position it is in and make sure it is pointing to the correct number of cylinder that your engine is. Then turn that switch back and forth in case its contacts are dirty and return it to the correct cylinder setting. Sometimes the contacts of the switch can get corroded inside the tach.
