pursuit2460
- Aug 24, 2004
- 193
I have read alot of the previous thread on the purple wire issue. I have a 93 johnson 225. I replace the stator, power pack, timmer base, and rec/reg. Today I went to turn on the engine and started just fine. Couple of mins. later I look at my tach and its at zero. Turn off the engine turn it back on and still no tach. I check the battery with a volt meter and it was charging at 12.24 as I accelerated the engine the voltage went up and still no tach. I looked one more time and the tach was working and the voltage jump to 13.05 at idle. Question my rec/reg came with the purple wire and I dont have it connected should it be connected and if so where. Also I have 3 purple wires under my center console. 1 goes to the ign. switch. 1 is on the horn. And the last one plugs in with the wires to the tach. Thats the purple wire that I dont have connected. Thanks
