Re: System Check Conversion - Oil Tank Sender Question
In case anyone might like to know, it is possible to modify the oil tank sender to convert it to system check. Here's how:
1. Remove the sender from the tank and remove the top of sender unit by unscrewing the two screws on the bottom of it. You will have to pry the top off.
2. Dig out the potting compound over the one nut and wire lug that connects the non-grounded side of the sensor. (you can tell which is which with a meter). The non-grounded side has two wire lugs connected to it.
3. Remove the nut, wire lugs and insulated washer.
4. Cut the white wire and discard the small wire lug
5. Place two 1/4" SS star washers over the black sleeve and put the big wire lug back on and secure the nut back down.
6. Re pot the area with some oil resistant sealant of your choice.
That's it. Now the connections to the sender are directly across the electrodes bypassing the electronic circuitry.
