fisheymikey
Thread starter- Joined
- Jul 30, 2012
- 450
hi everyone i did see on numerous post that one of the procedures is to check if there is voltage in the kill wires that could creat a problem.
my first question what symptom would it do. second witch kill wire? to the white wire or blue wire
here is the quote im referring too:
Disconnect the kill wires from the CD and connect a DC voltmeter between the kill wires and engine ground, turn the ignition switch on and off several times. If, at any time, you see voltage appearing on the meter, there is a problem in the harness or ignition switch. At NO TIME SHOULD YOU SEE BATTERY VOLTAGE ON A KILL CIRCUIT.
