SX-MD - Lower rear cover bolt stripped
harojs
Looking for OEM SS replacement bolt p/n, and a matching SS Heli-Coil Kit size.
( Is this a metric bolt ? )
Looks like the hole is stripped as well.
P.O. had used original bolt, that was half stripped, and a Heli-Coil in there, but I would like to re-do the fix properly with a new SS OEM bolt and a new SS Heli-Coil
Hoping someone may already have done this with an SX-MD model, or similar SX model and has sourcing info.
In meantime, I'm hunting around and will update this post on any sources I find.
-John
harojs
SX drive rear shifter linkage access cover for a 5.0L that has 3 bolts.
If you have a better term for the SX rear cover, I'm all ears.
harojs
Installed a SS Heli-Coil - worked fine found the VP OEM bolt on Amazon and had it in two days.
