Horigan
- Jun 12, 2016
- 746
I'd like to improve the corrosion protection on my joint venture '95 Volvo SX-M / OMC Cobra SX drive. It has multiple layers of paint and anti-fouling paint and each year I am priming and repainting areas that flake off due to corrosion. The main lower anode (Item 53 below) has a good electrical bond to the lower and is getting consumed. I'm using an aluminum anode since I boat in both fresh and salt water. I'm seeing there is a second anode available on the lower unit in the prop shaft bearing carrier (Item 27 below). This was apparently discontinued on later SX drives since I can't find a reference to this anode on later models and my local mechanics haven't heard of it.
Is anybody using this anode or have any thoughts on whether it's worth the $80 to gather all the parts necessary to install this anode?
