Afternoon,
Two weeks ago I had problems at the boat ramp shifting out of reverse. I trailered the boat and after further inspection found my outdrive oil was low (not registering on dip stick). I drained approx. 2 quarts of oil out of the drive. Found some small metal flakes in the oil, nothing too serious. After adding my 2.2 quarts of oil back through the dip stick hole I noticed what appears to be gear oil leaking from the lower unit pee hole. The hole is on the port side forward of the prop. Thge boat was parked in the driveway so I know it was not leaking before I changed the oil. Did I do something wrong or do I have another issue? Thanks for any assistance.
