SX-A thread repair
Jeff J
Vent plug started fine but never tightened up. What’s the popular fix? Heli-Coil?
kenny nunez
3/8x16” is the thread pitch. NAPA should have a Helo coil kit. Just to be sure thread the plug on a 3/8x16“ nut.
Jeff J
I may have a 3/8” kit. I was expecting metric.
Jeff J
I had to go to NAPA. If the constant supply of air through the bottom plug hole and the grease on the drill and tap worked as intended I should be in good shape. Thanks for the help.
Jeff J
Not such a great repair after all. It is leaking just sitting in the shop. This is the first time I ever have been grateful the gear oil is serviced above a vent hole. This would have gone unnoticed until I drained the water out of it in 100 hours. Need a different plug and seal than stock to cover the wider hole for the helicoil.
Get a threadsert vs a helicoil and use retaining compound. The oil leaks up the spiral
Jeff J
Not sure I want to risk digging the helicoil out at this point. I never had one leak like this (not the first time I put a helicoil in a wet location). I’m still not convinced the plug isn’t metric. It fits the new threads pretty loose while a 3/8” bolt sits a little tighter.
I drilled out the chamfer the o-ring is supposed to seal against. A Suzuki seal with the original plug may work but I am thinking a 3/8”-16 pan head screw would be better. It’s a shame the Suzuki plug uses a different thread. Had I thought I would run into trouble I would have installed threads for it.
Jeff J
No real pressure in this application so I would be willing to try a threadsert but I do not see how one would change the problem. There still would not be a good mating surface for the o-ring. Not on the inserts I have seen anyway so a gasket would still be required.
BRICH1260
Try coating the threads with a liberal amount of Tripple Guard grease. It may just give you the seal you need.
Jeff J
It looks like the helicoil and pan head screw with a gasket from a big Suzuki will be a good fix. I do not have a way to properly pressure test a lower unit but I did put some air to it and checked the plug with some soapy water.
