Re: Switching from inboard to outboard
I've been considering doing the very same thing to a 1970 Starchief I found nearby. It's a solid hull but it needs a total restoration and the motor is seized from sitting for 20+ years. I had pretty much passed on the deal but after riding in one that was done with a custom swim platform and motor bracket, I was seriously considering it. I'm just not real sure I want a bigger boat. The one I was in had a full width motor bracket, swim platform made out of aluminum, it was through bolted to added knee braces inside. The transom was rebuilt with two layers of 3/4" plywood, then a sheet of heavier aluminum on the inside at all through bolt locations. The knee braces were taken from an outboard powered Super Sport that was parted out. The motor used was a 200 hp Mercury which made that boat downright fast. Keep in mind that setting the motor back changes the ideal mounting height as well, you will most likely be able to raise the motor up a bit. Since that boat really isn't built for speed, you most likely won't see too much of a change in handling, if anything, I'd guess it will be an improvement due to the weight savings.
The best part of the whole conversion is the full height stern and the abundant space you will gain over the I/O set up. It will be even roomier than a factory outboard boat since you will not need or have a splash well.
